800 tranny creeping
Old 05-11-2009 | 02:22 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you might get lucky and thats all thats wrong. keep your fingers crossed.
Old 05-13-2009 | 08:16 PM
dslanec's Avatar
Well I picked it up today. They put a new motor mount on it and changed 2 fiber washers in the one way clutch. They loaded it on my trailer for me. I get home and the machine still creeps!! It now shifts easy so that is fixed. They were closed by the time i got home so i will have to call them tommorow. It is like they did not even test it out. If i put it in low it starts to creep right away. Could the clutches be out of allinment from changing the motor mount? Also the new motor mount has a different part number. Did they improve it because of to many failures?
Old 05-13-2009 | 10:26 PM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Here's the deal, the dealer did in fact change the 2 fiber washers out on the primary? I would challenge them on that, I've done a ton of those washers on the primary, and their function is to add space so the primary sheaves don't grab the belt at idle. Motor mounts with rubber bushings are a pre-fit and mount in pre-drilled holes.
bvandass
10-08-2015 10:13 AM
txkevin
09-21-2015 03:02 PM
Logan Collins
09-05-2015 09:03 PM
Haakon
08-24-2015 02:54 PM
Biggieshortie89
05-26-2015 09:01 AM
