ATC 70 points
Old May 13, 2009 | 07:36 PM
pcollins's Avatar
Smile ATC 70 points
just a few quick questions. i finally got my 70 running right. It turns out the last time i installed the points they weren't tight enough, and the gap slowly closed and made it run horribly. i adjusted the gap and re tightened the points. i just need to know, did running it with loose points for about a year possibly hurt anything? and what are the odds of it happening again after i tightened them pretty good. last question, what is the average life of a set of points on these things?
thanks guys.
Old May 14, 2009 | 07:26 AM
MuckUte's Avatar
I don't think any long term damage would have been caused by the points being loose. On the question of how long they will last, I don't have a precise answer but my most recent 70 arrival had points in it that almost looked like they had been in there since new and it was still running well. From what i've read they wear the part that runs on the crankshaft and this can make it hard to set the timing using the gap method. when this happens it is time to replace the points.
Old May 14, 2009 | 02:35 PM
pcollins's Avatar
thanks. come to think of it i should have dripped loctite on the treads of the screw. but it should stay tight. if not and it starts to run bad again at least i'll know whats wrong.
Old May 15, 2009 | 06:58 PM
MadMel777's Avatar
if your going to use locktite make shure you use the rite one ... you use red and youll never get the screws out ... id lean more twards a star/split type lock washer ... IMO
Old May 15, 2009 | 08:31 PM
pcollins's Avatar
it does have a lock washer on it thats why i didn't worry too much. although i did find out why the first owner soldered the wires to the condenser. i put in the new condenser a while ago and the wires tend to come loose. happened today, and this isn't the first time, and i had to push it home. if it happens again i'm going to solder them back together.
ReconBayou
Oct 31, 2022 05:37 PM
Customer Service #1
May 15, 2020 08:46 AM
EIF
Apr 20, 2017 07:15 PM
bigred20653
Oct 2, 2015 10:05 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
