Electrical Problems 800EFI
Old May 17, 2009 | 09:20 PM
think38's Avatar
Default Electrical Problems 800EFI
My 2007 Sportsman 800 up and died today. Was running fine. Went to plug in a small portable air compressor to the 12v connection. When I did, the machine quit. No electrical at all. No lights, no display, nothing. Tried connecting and reconnecting the battery -- no luck. Battery has a good charge on it. Fuse appears intact. All connections appear to be solid.
Suggestions?
Old May 17, 2009 | 10:09 PM
eggenz7's Avatar
fuse link blew in the ecu maybe?
Old May 18, 2009 | 05:43 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if your not getting any power, check the fuseable link, pull apart the pod to see if power is coming to the switch. make sure the kill switch on the handle bar isnt on as well. welcome to the forum
Old May 18, 2009 | 08:46 PM
think38's Avatar
How do I check the fuse link? Is there a fuse box my the ECU? The electric diagram in the service manual says there is a fuse box, but for the life of me, I can't find it (or recognize it if I'm looking at it).
Old May 18, 2009 | 08:51 PM
700 sportsman's Avatar
Did you check the fuses in the front box under the removable panel?
Old May 18, 2009 | 09:36 PM
think38's Avatar
Got it. Problem was one of the main fuses. For reference, the fuse box is not located behind the access panel just under the pod. That's the location of the ECM. Instead, the fuse box (at least on mine) is located under a small access panel inside the front storage compartment.
Old May 19, 2009 | 05:08 AM
I'm a Genius Lol
Old May 19, 2009 | 05:13 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Originally Posted by 700 sportsman
I'm a Genius Lol
now i can retire, the forum is in good hands. j/k the fuses are all in the front staorage box panel on the 800's that i know of.
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
