1999 KODIAK U joint replacement
Old May 18, 2009 | 06:43 PM
frede zorn's Avatar
Default 1999 KODIAK U joint replacement
1999 yamaha kodiak needs front u joints. can anyone tell me how to remove the front drive shaft???? Thanks
Old Aug 22, 2009 | 10:17 PM
k.hughes425's Avatar
There are ring clips on the top of each end remove them with a ring clip puller and beat them apart with a hammer!
Old Sep 1, 2009 | 10:44 PM
jn452's Avatar
Default what about the u-joint on the transfer case?
I am having some what of the same problem with my 93-95 (can't remember exactly) Kodia 400. Some thing in the front end was squaking so i got all m=nem bearings seals and u-joints for the front drive train. Every thing was going well till i got to the u-joint for the drive shaft that is attaced to the transfer case. How in the wolrd do you remove and replace that one. And please do not tell me i have to pull the transfer case. everything else has been easy. Please help
Old Sep 2, 2009 | 06:09 PM
Default inner u joint replacment
If you remove the outer part of the axle from the hub, by removing the axle nut, tierod end and lower or upper ball joint, then and pull the axle away from the diff. it will pop right out to make it easy to get to, It may take a few good tugs by a healthy man but it will pop right out then you can get the u joint off easy!
toonces
Jul 28, 2015 01:58 PM
kdg723
Jul 25, 2015 01:20 PM
Peter_
Jul 18, 2015 07:06 AM
musselmark
Jul 17, 2015 02:40 PM
RedRancher
Jul 10, 2015 06:36 PM
