2001 Polaris Exploer 300 Problems
Old May 20, 2009 | 06:34 PM
twinkies09's Avatar
Angry 2001 Polaris Exploer 300 Problems
i have a explorer and i have a an issue with it when i put into gear it makes a grinding sound then when i get get going it seems like it doesn't have much power is this common for explorers too have these kind of problems
Old May 20, 2009 | 07:10 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
are you sure its going into gear all the way. it might need the linkage adjusted. as far as power goes its not too bad for a 2 stroke 300. if it doesnt seem to have good take off or any top end, maybe check the blet and or clutches for wear. the seconadry buttons do wear out. imo
Old May 21, 2009 | 05:59 AM
ftwflh's Avatar
Check the "bell crank" arms on the tranny.These are aluminum and strip out after time.can get loose too and not let it shift completely
skittero
35
Mar 1, 2019 12:39 AM
bonanza 440
Jun 26, 2015 10:01 PM
Big600twin
14
Jun 16, 2015 09:30 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
