Need Answer About Starter Fast
Old May 23, 2009 | 07:28 AM
gordster1122's Avatar
Default Need Answer About Starter Fast
k 2 days i was cruising around and shut off my quad and tryed starting it back up and couldnt just makes a clicking noise i have to pull start it now tryed charging it and checked to make sure the wire were tight someone help doing a trade in in 3 days
Old May 23, 2009 | 08:00 AM
TLC's Avatar
TLC
Most likely you have a stuck bush in your starter, take the starter apart and clean and lube the bushes so the move freely again. Get to the starter by removing the air box is the easiest way.
I had to do it, The bad news is it takes up a afternoon, the good news is there no parts to buy.
Old May 23, 2009 | 08:10 AM
trainfixerjer's Avatar
I had the same problem and my battery was bad. Can your lights turn on? If you dont have enough juice for the starters they will click. if not the battery than the starter like TLC said. =)
Old May 23, 2009 | 09:23 AM
yup the lights work everything works just wont turn over have to pull start it
Old May 23, 2009 | 10:41 AM
HeftyLefty's Avatar
Clean all cables / connection points in battery / starter circuit with WD40 or similar, they probably have corrosion due to moisture.
Cummins Driver
Sep 11, 2019 01:22 PM
akbrewcrew
Aug 9, 2015 10:54 PM
house1
Aug 9, 2015 10:49 PM
ScopeZ_
Jul 28, 2015 01:44 AM
ghost civic
Jul 15, 2015 10:48 PM
