01 Polaris Sportsman 500 HO weep hole leaking
Old May 26, 2009 | 06:02 PM
Print_head's Avatar
Default 01 Polaris Sportsman 500 HO weep hole leaking
Anyone have any tips to get to the weep hole on the water pump ? Do I need to pull the motor out ?
Old May 26, 2009 | 07:17 PM
upnort's Avatar
The weep hole should be on the right side of motor near bottom. There have been many instances of this. I have been through a few. It is due to the mechanical seal leaking inside. Some have changed theirselves but if you bend the shaft then the motor has to come apart. Do a search for weep and should find lots of discussion on it.
Old May 26, 2009 | 08:00 PM
If you damage the counter balancer/water pump shaft,THEN the motor will have to be pulled out! About as cheap (about 2 hrs labor plus seal in most cases to let dealer do it) than to buy the tool which is about the same price,Plus cooling system has to be thoroughly bled to get all air out OR will overheat!
neilbedwell
Nov 10, 2018 11:02 AM
bikedad3
Jun 29, 2015 08:58 AM
bonanza 440
Jun 26, 2015 10:01 PM
yellowpolaris
Jun 21, 2015 11:13 AM
May 27, 2015 11:15 AM
