no spark 2001 660r raptor
Old May 27, 2009 | 08:40 AM
mikesbikesmalden's Avatar
Default no spark 2001 660r raptor
ok here is the deal atv was running but leaking gas bad. i pulled the carburetors off rebuilt them and installed a new starter clutch gear. now i have no fire. i have changed the igntion coil it did nothing i installed a big gun rev cdi box and my reverse light comes on and it will not crank. i tryed to unplugg the charging side of the stator still no spark. i hate ohm meters but i have a book and tested to best of my ability and all test good.
Old May 27, 2009 | 10:27 AM
Kevin R.'s Avatar
I would check all the grounds first and all the wiring to make shure nothing got unpuged or damaged. After that it's time to get the volt/ohm meter out and start tracing wires. I found that rmstator has the ohm's limits on there website and which wires to check for your stator.. Other than that it's hard to say what's wrong.
Old May 27, 2009 | 11:06 AM
no broken wires all grounds have been rechecked and recleaned more then once and everything shows ok on the meter
Old May 27, 2009 | 09:08 PM
Kevin R.'s Avatar
Well if the power side and ground side is good, I would ohm the stator out. The cdi box is very hard to kill.
Old Jun 7, 2009 | 07:35 AM
ok i installed a new rmstator and cdi box fired right up. ran great for 2 hours but it would not idel it would snap and pop when you let off the gas and coast. shut it off went back to ride it and it will not start i shot starting fluid i nthe air box nothing changed the plug nothing the spark looks weak even with resistor cap off is there a air gap setting on the pick up coil?
Old Jun 7, 2009 | 09:14 AM
Kevin R.'s Avatar
I don't think there is an air gap setting on it. At least not on anything I've worked on. I would check all the plugs and make shure that the pins are set right. I bought a rmstator kit for my warrior and the stator was built poorly at the plugs. I had to redo them after the first ride, kept coming loose and backing out of the plug. It's in rout back to them for the pick up coil going bad. I have a rickystator in it now and it seems to run better. Also, I would check the flywheel area and make shure that there's nothing loose floating around, or any kind of metal on the outside of the flywheel, That can cause a weird signal to the cdi box.
black_thunder
Jul 22, 2015 06:01 PM
blpersinger
Jul 15, 2015 09:56 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
