new to the site...need help
Old May 28, 2009 | 09:53 AM
lhayden's Avatar
Default new to the site...need help
Hey gang
I just but a mic 250 cc...I have gotten the VIN number and need help trying to identify what it is. I have heard that parts are hard to get but any help would be appreciated. HERE IS THE LINK...
http://www.shutterfly.com/lightbox/v...cd1d30d33b21f1
THANK YOU
Lyle
Old May 28, 2009 | 02:07 PM
Sawyer's Avatar
your link doesn't work, try up loading the pic. here.
Old May 28, 2009 | 04:10 PM
lhayden's Avatar
how do i upload the pictures here???
Old May 29, 2009 | 04:22 AM
outofline's Avatar
You can go to your profile and creat a Gallory here or host them elsewhere like Image hosting, free photo sharing & video sharing at Photobucket like I do.
Old May 29, 2009 | 04:30 AM
HawkeyeRider's Avatar
Photobucket is easy and free, create an acct, then upload pics. when you want to post pics in a message, just copy from photobucket and paste here.
Old May 29, 2009 | 06:07 AM
lhayden's Avatar
Default thanks guys
I went to the profile section and added pictures to my album...hope it works...thanks for all the help in advance...trying to find out if I am FUBAR on this MIC ATV
Old May 29, 2009 | 04:17 PM
Sawyer's Avatar
I've seen those before.... a 250 with a CVT trans is it not??? What factory was it made in? It should have a plate on the frame. The engine pictures are dark so its hard to see. What's wrong with it or what parts do you need?
Old May 29, 2009 | 06:11 PM
lhayden's Avatar
Default answer to issues????
I think it has a short in it. When I picked it up it ran fine no problems...then I got it home and installed a new battery and it still fired up. But, when I turned the toggle switch off (yes I said toggle switch...the previous owner lost the keys and used a toggle switch spliced with speaker wires...yes I said speaker wires) then engine sounded like it was turning over. I pulled the speaker splices out of the toggle switch and it cut off. I connected the red and red/white wires from the old key switch together to get it to run hot and it fired right up, but then when I turned the handle switch to off the engine sounded like it was still trying to turn over. So, short in the stator, starter, cdi???? I also was having a hard time getting it in gear when the engine did fire. I am going to change the oil and plug this weekend and see what happens. I will need a new key switch..two wire, most that I have seen out there are four wire but I do not know what the other wires are to without a wire diagrahm or owners manual.
Old May 30, 2009 | 02:56 PM
Scalerman's Avatar
Hey lhayden
Welcome to the ATV forum.
After checking out the Pic's, your quad is a 250 Commando made by QIANJIANG.
Seem like you have a wiring problem.
I have the 250 Service Manual in PDF format, with the proper wiring diagram.
For some reason the PDF file will not upload to this post.
If you want, PM me your email and I will send you the manual that way.
Hope this helps.
Dave
Old May 30, 2009 | 11:03 PM
lhayden's Avatar
Default email
wolverine23@prodigy.net
