Restoring old 125 atc
Old May 30, 2009 | 12:51 PM
michael125m's Avatar
Question Restoring old 125 atc
I have an old 125 atc honda 3 wheeler that has been sitting in my shed for 14 years. I recently got it out to see if i could revive it. Cleaned carburetor and installed new gasket kit also in installed new gas tank. I got it cranked but it won't idle on its own. Any ideas would be appreciated.
Old May 30, 2009 | 08:42 PM
sdm111's Avatar
2 strokes or 4
Welcome to the forum. I know you said you cleaned the carb. but after sitting that long maybe at least get a new pilot jet only about $5.00 from the dealership. Also if it only runs on choke that usually means a clogged idle jet. Other than that try unscrewing the cable out a little from the thumb throttle if that's not enought or if it can't be adjusted there try unscrewing it a little from the top of the carb. that should get you close then you can tweak it with the idle adjust screw.
Shifts
Jul 3, 2015 07:59 AM
quadnob
Jun 7, 2015 07:55 AM
Steele
Mar 20, 2002 12:34 PM
xepathfinder
Nov 15, 2000 09:23 PM
