1995 magnum 425 shifting difficulties
Old Jun 1, 2009 | 11:03 AM
Fever's Avatar
Default 1995 magnum 425 shifting difficulties
So my girlfriend bought this machine yesterday and it is VERY difficult to shift from High to Reverse and vice/versa. The only way to get it to shift is to do a sharp "palm strike" on the shift lever. Shifting into/out of Low is a much more "normal" feeling shift. The machine has 2,200 miles on it and it in runs very well. I haven't picked up a manual for it yet, but I was wondering what your thoughts might be on how to remedy this. The previous owner claims to have changed the tranny fluid. Suggestions?
Old Jun 1, 2009 | 11:08 AM
02magnum500's Avatar
Gets his share of deer.
It may be idling too high, does the machine want to creep ahead while in gear? Should idle at about 1150 rpm you wont be able to verify this being you dont have a tach on the atv but you may have to just listen for high idle?
Old Jun 1, 2009 | 11:36 AM
Fever's Avatar
The idle feels very good. I've got an '05 scrambler, so I'm familiar with what you are talking about. I guess I could idle it down a bit and see if that helps.
Old Jun 1, 2009 | 11:43 AM
Or try and shift it with the machine OFF and see if it shifts better? If not , it could be linkage adjustments.
Old Jun 1, 2009 | 12:57 PM
Fever's Avatar
It seems to be just as difficult when the machine is not running, so I'll tinker with the linkage. I certainly appreciate your help on this.
Old Jun 1, 2009 | 03:29 PM
drlang's Avatar
The shifter itself can be taken apart cleaned and relubed. They can get nasty inside.Doc
Old Jun 1, 2009 | 03:38 PM
TLC's Avatar
TLC
Do it yourself,not sure about the 425 but the SP500s tranny takes "chaincase fliud",a full sythetic brand is the top choice.
Old Jun 1, 2009 | 04:30 PM
ftwflh's Avatar
Ditto on this plus check the bellcrank on the tranny where the rod hooks they are alluminum and do strip out
Old Jun 2, 2009 | 01:38 AM
CaptainQuint's Avatar
That gear selector tends to hold water. This rusts all of the detents and switches which causes shifting problems. You might want to clean and adjust the gear selector and see if that fixes it. It's not a bad idea to seal the boot up with silicone and snug the top up with a zip tie.
95wolv
Sep 27, 2024 12:00 PM
Gwolf228
Feb 18, 2017 01:36 AM
Clint Russell
Sep 25, 2015 03:20 PM
BigCam
Sep 16, 2015 01:53 AM
Sep 9, 2015 06:57 AM
