Polaris Belt Getting Wet... What can I do??
Old Jun 1, 2009 | 03:16 PM
pcruz321's Avatar
Default Polaris Belt Getting Wet... What can I do??
Can I know what can I do, so that my ATV belt wont get wet every time I go in water... Help, I have a Polaris Touring 800, 2008
Old Jun 1, 2009 | 03:23 PM
TLC's Avatar
TLC
Make sure that both intake and exhaust belt housing breathers are on tight and the belt housing cover is on right.
Nowhere else water can get in unless your just in too deep of water.
scootergptx's Avatar
Supersock
Hired Gun!
Make sure the seal on the cover is not kinked, and the drain plug isnt' leaking. You can use silicone as an alternative if the gasket is broke/damaged. A little bit more of a pain if the back cover is leaking.
Also check the breather tube for the cover and make sure it's not leaking too.
Belt shouldn't be getting wet every time unless you're really flying when you hit the water, or you getting up to the seat in water.
Old Jun 1, 2009 | 03:28 PM
TLC's Avatar
TLC
Dont for get about the breather pipe you cant,see thats under the seat and air box,not just the pipe in plain sight.
Old Jun 2, 2009 | 10:42 AM
slikjr's Avatar
All as above is good advice. I wouldn't recommend any silicone though, makes getting it off a REAL pain, I have a friend who did it. Take the belt cover off, clean the surfaces real good, reinsert the gasket without any twists, put a bead of your favourite grease over that, and reinstall.
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
toonces
Jul 31, 2015 09:27 AM
Mikesohio
Jul 26, 2015 10:51 AM
trouttracker
Jul 20, 2015 11:54 AM
