Honda gas tank
Old Jun 1, 2009 | 04:24 PM
roger46982's Avatar
Default Honda gas tank
Purchased a replacement tank guaranteed not to leak on EBay, well the sucker leaks like a sieve. Now the guy claims it isn't his tank so I am stuck. Any of you guys ever have any luck patching one? HELP
Old Jun 1, 2009 | 04:34 PM
TLC's Avatar
TLC
I was watching "Montser garage" years ago,and they patched a metal gas tank with this puddy like stuff. Forget what it was called,but everyone including Jessie was amazed that it worked.
Old Jun 1, 2009 | 06:21 PM
MadMel777's Avatar
JB weld is the name of the epoxy most people use on tanks (i believe) make sure the tank is clean an dry before you apply it
Old Jun 2, 2009 | 03:25 AM
roger46982's Avatar
Thanx guys, I tried JB Weld on another tank to no avail but it was really shot.
Old Jun 5, 2009 | 07:56 AM
roger46982's Avatar
Found some stuff at Ace hardware, two part putty, seems to be doing the trick. If I ever find all the leaks.
Old Jun 6, 2009 | 05:32 AM
chuck_raduenz's Avatar
i had a 83 atc steel tank. when i pressure washed it it took off the epoxy the prior owner had put on it. it was like 4 pin holes. well i took a grinder too it with a wire wheel. and cleaned the tank out. let it dry. then i took a torch and solder to it. never had another issue with it. guess it depends on how big the hold are and if it is a steel tank.
Old Jun 6, 2009 | 05:34 AM
you know if you wanted to they make a liner for the inside of the tank. think it involves cleaning the tank out good. then dump the liquid in the tank and roll the tank tell it coates the whole inside of it with a liner. iv never used it but iv seen people use it. im also not shure how good and how pricey it is.
Old Jun 21, 2009 | 07:52 PM
SMFREY's Avatar
There are a couple things you can do
I had the same issue and looked up Clarke and bought new replacment plastic tank
No more rust issues
Or you can work with your steel tank
Epoxy no work so good
Best to clean tank
Easy way take to radiator shop have them clean and repair simple cheap
All you would have to do then is repaint
Done
You can then also get fuel tank coating to seal inside to keep from continuing to rust
Several companies sell this I have an Eastwood catalog it is 2007 it shows a kit for motorcycles under $40 for tanks to 5 gallons has one can metal wash one can fast Etch and one container of sealer
But when all is said and done it is what fits your pocket book
Good luck
Ray
Cummins Driver
Sep 11, 2019 01:22 PM
Aug 5, 2015 02:10 AM
Jul 22, 2015 05:00 AM
Aitch
Jul 21, 2015 09:40 PM
Shifts
Jul 3, 2015 07:59 AM
