Warrior trouble
Old Jun 6, 2009 | 11:56 PM
wideopenracing5's Avatar
Default Warrior trouble
I Have a 1997 warrior with a 396 stroker and cp racing piston. The motor has been rebuilt a few times for different reasons. So here are my problems.. around mid throttle i gets a very inconsistant rpms and sputters but when its wide open it has no problem. I tried rejetting it but didnt change a thing. I took out one of the plastic plugs on the case and turned the motor over and it shot oil out of it like it has too much crank case pressure. Im wondering it have some bad rings or a leaky intake valve. Anyone else have these problems? any suggestions?
Old Jun 7, 2009 | 12:07 AM
91Warrior357's Avatar
have you tried adjusting the needle at all? also does it smoke any? valves might be a prob if the valve lash is way off or the seats are worn.
Old Jun 7, 2009 | 12:19 AM
no smoke and i got the valve lash within spec. I never checked the crankcase pressure before so i dont know if they are related
Old Jun 7, 2009 | 07:46 PM
Do the warriors just do that or is it just mine?
Old Jun 7, 2009 | 08:04 PM
i dont thing ive ever pulled the timing plug out on mine, but as long as the crankcase vent isnt clogged it should be fine, if its sputtering at around mid throttle then most likely the needle needs to be richened up.
Old Jun 7, 2009 | 08:19 PM
ive already riched it up and changed the jetting and nothing happened.
Old Jun 7, 2009 | 08:22 PM
when u say u try to richen it up did u richen it by the mainjet or what? have you tried raising or lowering the clip on the needle?
Old Jun 7, 2009 | 08:36 PM
Main jet, Clip, combos of both.
Old Jun 7, 2009 | 09:50 PM
is your accelerator pump working freely? also the stock accelerator pump spring is trash from the factory is doesnt have enough tension to it, and cause the pump to work poorly and hang up, get a clicking pen and take it apart and take that spring and use it on your accelerator pump, it will work much better and possibly remove that little sputter you have.
Old Jun 7, 2009 | 11:01 PM
I just might try that but i dont know it that is the problem because wouldnt i still have a problem when it is wide open?
