Warrior trouble
Old Jun 7, 2009 | 11:05 PM
91Warrior357's Avatar
Originally Posted by wideopenracing5
I just might try that but i dont know it that is the problem because wouldnt i still have a problem when it is wide open?
its hard to say, but whether or not its the problem thats a good mod to do, those stock springs are trash, it could be a few things, if its not the carb then im thinking of something along with the valves, what where the reasons it had to be rebuilt?
Old Jun 9, 2009 | 12:18 AM
wideopenracing5's Avatar
Nevermind accelerator pump wouldnt affect wide open. but its not like a starv when i hit it. It backfires when i get off the gas too. Could it be something in the ignition?
Old Jun 9, 2009 | 12:50 AM
yea its possible, warriors like to toast stators, but usually when the stators start to poop out they become are real pain to start, almost seems like its running rich if its backfiring but it could also be ignition, even worn valve train can do that.
Old Jun 10, 2009 | 12:00 AM
The first time it was rebuilt is because i went to oaklahoma and sand goes through a k and n filter. the second time my local quad shop forgot something with the rings i dont remember it was awhile ago and its been tuning it in ever since.
Old Nov 28, 2009 | 09:17 PM
  #15
Sorry It's been awhile and i dont mean to start up old threads but is there anyway to tell if its the ignition?
Old Nov 29, 2009 | 01:43 AM
  #16
beefy46172's Avatar
Loves To Ride!
Just check voltages at the coil/stator etc. Generally ignition problems make it a pain in the *** to start too though and don't stop at WOT. I had some pain issues with my Warrior a few years back when I rebuilt it and it ended up being a torn carb boot; which makes it impossible to get jetted or running right. I'd make sure your intake system and fuel system are all clean, sealed, and working properly.
Old Nov 29, 2009 | 01:46 AM
  #17
beefy46172's Avatar
Loves To Ride!
Also, I wouldn't worry too much about the oil shooting out. As long as your breather hose isn't plugged up you should be fine. I pulled a real wise-guy move a few weeks back when I checked my oil before riding and forgot to put the dipstick back in. I noticed it quick and had just been putting around but my pantleg and front fender were doused in oil.
Old Nov 29, 2009 | 02:09 PM
  #18
Im going to check the breather hose. But would my carb boot seal up at WOT? I think i remember my carb boot having a little crack or worn and i didnt think anything of it.
Old Nov 30, 2009 | 08:52 AM
  #19
beefy46172's Avatar
Loves To Ride!
If its got any crack it needs to be changed, end of story. Otherwise you never know when it may or may not suck air in through it and thats why it just runs like crap at mid throttle. Plus once its cracked its only going to get worse. Mine ran fine at WOT but crappy in the mid-range when mine was split open on one side.
Old Nov 30, 2009 | 11:18 AM
  #20
I'm sitting In school right now but when I get home I'm going to check it.
With all the money in yours how well do you like it? Even being heavy and all.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
Bernhard
Sep 25, 2015 12:45 PM
