2000 Sportsman 500 Clutch problem
Old Jun 11, 2009 | 08:14 PM
steamstud's Avatar
Cool 2000 Sportsman 500 Clutch problem
My Sportsman locked up on me. I removed the clutch cover and found a piece of flattened steel lodged between the belt and the driven clutch. The steel is 1"X7" and about 1/16th" thick. It is warped and flattened. Best I can figure is that is might be the bearing cover on the drive clutch. The clutch has just a little bit of wobble now. I took out the bolt that holds the drive clutch in but this clutch doesnt want to come off. Is there something else I need to do or is their a tool to take it off? Im working without a manual. I took the steel to the local polaris dealer (an hour away) and they didnt have a clue what it was and did not have a bearing cover to compare it too. I appreciate any help someone can give me.
Old Jun 11, 2009 | 09:52 PM
eggenz7's Avatar
yes you need a tool to get it off....it fits like a flywheel on a lawn more...cone shaped shaft with the clutch on it..over time the grab ahold of each other very well
Old Jun 12, 2009 | 01:19 PM
bcdudley's Avatar
This sounds like the same thing that happened to me a while back. Check out the pictures I posted on the second page and see if it looks the same. I wound up having to buy a new clutch and belt for mine.
http://forums.atvconnection.com/pola...nsmission.html
I found both for a decent price on ebay. Less that $100 for everything.
Old Jun 12, 2009 | 04:51 PM
steamstud's Avatar
Default clutch problem
This is what I found wedged between my secondary clutch and belt.
polaris atv picture by steamstud - Photobucket
Old Jun 13, 2009 | 08:19 AM
drlang's Avatar
That doesn't belong in there to my knowledge. I think the last guy that was in there might have forgot it.
Land_shark1
Jul 10, 2015 12:53 AM
wbfjim
Jun 8, 2015 06:20 PM
Fullblast
May 26, 2015 12:38 AM
Tray
Jan 14, 2001 03:18 PM
