Wondering if I should Clean my Chain or not that is the question??
Old Jun 11, 2009 | 11:11 PM
Beau49's Avatar
Default Wondering if I should Clean my Chain or not that is the question??
I have a 1996 300 xplorer and I have it somewhat disassembled to work on a few things. I am about ready to Button it up but just wonder if I should try to clean off some of the last 13 years of mudd, grease, oil, & everything else that has been used on the chain overtime. The chain looks to be in fairly good shape at least by what I can see of it that is why I would like to clean it up a little.
The Chain on this machine has o-rings on it so that is why I figured I had better get some idea's from you guy/gays that have had these toys longer than me.
I was thinking of taking some of the foamy engine cleaner and spraying it down letting it soak then rinsing it off with a garden hose. What about using carburetor cleaner on it? One other idea I was thinking about using if neither of foamy engine cleaner or carb cleaner would not work is taking some kerosene or diesel with a brush and clean them up that way.
I guess I should mention that it is the middle chain and the forward chain I want to clean up. I hope not to have to disassemble this little beast for along while.
If I can clean the chain with something I was planning on putting some chain lube I have on the chain but is their something better to use than Chain lube or a certain brand that is better than others?
Old Jun 12, 2009 | 12:20 AM
chuck_raduenz's Avatar
first thing id do is check the sprokets. if the teeth are starting to look like a saw blade its time for new sprokets and chain. if there fine. id check the o-rings in the chain are missing, cracking its time for e a new chain. if there fine there are chain cleaners out there. but carb cleaner, or harsh cleaners i woudnt use. but iv never really cleaned a 0ing chain. i had a oring chain on a wheeler i had before. and all i did was oil it. just becuse of the orings. id use soap and water with a brush. or a cleaner that wouldnt hurt the o-rings asuming there in good shape. but im shure other people who have more exspearinace can say what they use.
Old Jun 12, 2009 | 06:32 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
I would just blow any loose stuff like dirt dust etc.. off with compressed air and spray it back up with chain lube. I am a Electrician by trade and don't use any contact cleaner on this chain with O-rings.......Many contact cleaners will damage rubber and plastic.........Not all but most will............Caper...............
Old Jun 12, 2009 | 07:19 AM
scootergptx's Avatar
Supersock
Hired Gun!
Instead of buying the cleaner, buy a chain scrubber.
But as old as the quad is, it may be just as easy to buy a new one.
If you need chain and/or sprockets, a guy using sledpartsguy over on ebay has some good deals.
Don't let the name fool you, he has tons of quad stuff too.
Old Jun 12, 2009 | 01:32 PM
700 sportsman's Avatar
you can soak it in diesel fuel to clean it up and lube it too
VRRRRT
Jun 27, 2015 09:38 AM
scaldwellk
Jun 19, 2015 05:08 PM
cornermike
May 27, 2015 10:04 PM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
