1998 sportsman regulator/rectifier location
Old Jun 14, 2009 | 05:34 PM
flhusa1's Avatar
Default 1998 sportsman regulator/rectifier location
where exactly is the rectifier located at? in the parts diagram it shows it somewhere in the front. i saw what i thought was it at the the bottom of the terminal board. according to the diagram that looks to be the rev limiter. i need help so i can get my brother in law bike back charging. was going to check for incoming a.c. voltage to the rectifier if i can find it.
Old Jun 14, 2009 | 06:19 PM
war1ock's Avatar
not really sure but it might be on the front down and to the left( if your sitting on the bike) like a little black box with wires coming out of the bottom
Old Jun 15, 2009 | 06:02 PM
Located at lower left front behind radiator a little,has red,yellow,yellow/brown,and brown wires on module. Pop the front panel and look down!
Old Jun 15, 2009 | 10:46 PM
Mik777's Avatar
Old Jun 16, 2009 | 05:47 PM
Rutcutter's Avatar
If you need one I have a used one in great shape..
Old Jun 18, 2009 | 11:15 PM
flhusa1's Avatar
found it. had to remove front grill to get it removed. replaced with new one but had a bad wire connector. all is good now headlight gets brighter with engine rpm and no more dead battery.
thanks for the info
ScopeZ_
Jul 28, 2015 01:44 AM
kdg723
Jul 25, 2015 01:20 PM
clsharky
Jul 13, 2015 02:07 PM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
