1986 250R cutting out
Old Feb 17, 2001 | 07:08 PM
KC8848's Avatar
250R is cutting out. Any suggestions would be appreciated, sometimes the obvious is overlooked when you've been trying to troubleshoot for hours. I've tried jetting it for lean and rich. We've replaced the stator coil, ignition coil and the pick-up coil and still cutting out on top end. Have tried two seperate carbs on it. I have a race tomorrow and desperately need any suggestions that you can offer.
Old Feb 17, 2001 | 07:48 PM
TRX250Rracer's Avatar
try a spark plug.. but i would check the CDI box
Old Feb 17, 2001 | 08:02 PM
KC8848's Avatar
Just got through trying a CDI box which we know is good from another 250R that races with us. Didn't help. We've tried 3 different spark plugs with no improvement. Am now trying some adjustment to the new boysen reeds put on last night. Thanks for the suggestions as we are completely stumped right now.
Old Feb 17, 2001 | 11:17 PM
PaulJ's Avatar
Are you getting "blow back" through the carb? That would indicate your reeds are not sealing at high RPM's.
How about have you looked at the possibility of your crank seals going out? The crankcase has a lot more pressure on it at high RPM's, and if the seals are weak, it will cause the scenario you are describing.
Old Feb 17, 2001 | 11:20 PM
trcagle's Avatar
air leaks anywhere? around carb boot? air boot?
stator cover? clutch cover? anywhere? spray it all w/ WD40 while its running and listen for engine speeding up that would indicate an air leak..
Old Feb 18, 2001 | 09:17 AM
400exalltheway's Avatar
is your compression good?
Old Feb 18, 2001 | 01:58 PM
RickRitter's Avatar
Try this , gap the spark plug to .020" and try it.
Old Feb 18, 2001 | 02:58 PM
ROLLpsi425R's Avatar
i guess you checked that there is good spark (no loos wires that could not be connected).
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Bernhard
Sep 25, 2015 12:45 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
