Need help from a Warrior owner that knows how to use a Multimeter
Im in need of help from a Warrior owner that owns a multimeter.
If you could, i need you to check for continuity on your reverse lever switch.
Just unplug the wire coming off the lever, connect a lead from the multimeter to the wire end and the other lead to ground( frame or bolt) and cycle the lever from reverse to forward and let me know which position has continuity and which position doesnt.
If anyone can take the time to do this for me i would greatly appreciate it. Thanks in advance.
i downloaded that manual but im not 100% sure its accurate for my year as a few things seem different from my actual quad as to what is said in the manual. The reason im asking for the help is because im trying to see if my reverse switch is actually bad or not.
On my quad, in the forward position, i have continuity(has a OHM reading) but in reverse i have no continuity(no OHM reading). This isnt what the manual says but ive tried 3 different switches and they all gave the same result so i just wanna be sure.
