82 200 atc front end swap
Old Jun 16, 2009 | 09:09 PM
3wheelcrazy's Avatar
Default 82 200 atc front end swap
I was wondering if the front end off of an 83 185 with solid forks will fit onto my 82 atc big red with shocks. I know I have to do the swap at the goose neck but I want to make sure it will fit. It's mainly just a temp fix until I can locate the correct forks but I found I a 185 stripped frame with a complete front end on it cheap but its the solid forks so I want to make sure it will fit before I buy it.
Old Jun 18, 2009 | 07:14 PM
MadMel777's Avatar
i swapped the front end of my 200 to my 185 for the shocks and front brakes with out any problems ... if that helps
Old Jun 21, 2009 | 07:29 PM
SMFREY's Avatar
It shouldfit no problem
I put a 200s front end on my 78-ATC90
Just had to change the steer stops
But in your case should fit
Good luck
Ray
STLyamwar
Jul 25, 2020 04:44 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
toonces
Jul 28, 2015 01:58 PM
tweeder
Jul 5, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
