problems starting help please
Old Jun 20, 2009 | 09:23 PM
pulldog500's Avatar
Default problems starting help please
Hi
I have a 03 raptor. it was working fine but today the starter started acting up. It has a hard time turing over. I makes loud noises and like a clunk/snap. and I hear it clicking the starter relay. I make sure the the clutch handle is all the way in when trying to start.
I think the starter is done. But could my one way clutch be going? and that might be why the starter is done?
thanks for the help
Old Jun 20, 2009 | 09:31 PM
mschillingii's Avatar
sound like could be starter or starter gear. only one way to tell for sure pull it and bench test it
Old Jun 20, 2009 | 09:41 PM
91Warrior357's Avatar
sounds like the one way clutch is about done, its common on the raptors there poorly designed, replace it with a LA one way and you should be good...a sheared keyway is another possibility but most likely its the one way clutch.
Old Jun 20, 2009 | 09:54 PM
pulldog500's Avatar
just the one way clutch? or the starter to?
Old Jun 21, 2009 | 01:56 PM
pulldog500's Avatar
checked the starter. it works fine when nut under load. when I put it all back together its still doing it.
I was looking at one way clutches on ebay. some kit come with a gear and some don't. witch would i need if it is the one way?
also will it hurt anything if i keep driving it?
thanks
Old Jun 21, 2009 | 09:51 PM
that extra 52 tooth gear is an option just incase your old one got messed up from the one way going out, yours should be fine most likely, this is what im talking about LA Designs, Raptor one way, Yamaha Raptor 660 starter Clutch, LL Extreme the majority of raptor 660 riders use L&A one ways its a common part to poop out, and the L&A will last 4ever plus its a lifetime warranty, make sure first that it is indeed the one way needing to be replaced before you get it, but to me it seems like thats the problem.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
