tie rod
Old Jun 27, 2009 | 10:50 AM
michael l's Avatar
Default tie rod
looking into getting a set of tires.. and have found out that 9" wide is the widest you can go on a stock rim without it rubbing.. how many has flipped the tie rod? does it help out or could it make things go out quicker? need some info before i get some tire.. friends got a set of 28x10x12 front and 28x12x12 rear mudzilla's for sale CHEAP... i need to know something quick please..
Old Jun 27, 2009 | 10:51 AM
michael l's Avatar
sorry.. bike there going on is a 05 sportsman 800 with 2.5" lift in front...
Old Jun 27, 2009 | 04:56 PM
gomer4877's Avatar
have 500 miles on my 08 SP800 with tie rods flipped and no problems, am running 27", XTR's, also ride with a 06 SP700 with 28" Outlaws, tie rods flipped and no problems,if you set the toe to spec. you won't know there flipped.
Old Jun 27, 2009 | 09:50 PM
michael l's Avatar
thanks for the help... one more question.. when i flip the tie rods do i flip just the end by the tire or do i flip it all??
Old Jun 27, 2009 | 10:24 PM
Off_Road_Ram_01's Avatar
suscribing to this thread cause I may be doing the same thing soon.
Old Jun 28, 2009 | 06:53 AM
helmethair78's Avatar
You could get some 1.5" wheel spacers.
Old Jun 28, 2009 | 07:32 AM
michael l's Avatar
could, but if flipping the tie rod does the fix and doesn't mess anything else up then it sounds good to me... and it's FREE...
Old Jun 28, 2009 | 08:37 AM
gomer4877's Avatar
just flip the outter ends
Old Jun 28, 2009 | 01:27 PM
michael l's Avatar
got it.. flip the outside ends of the tie rods and then i'll need to check the toe adjustment on it.. the toe adjustment should be around 1/8" on each tire correct..
thanks for all the info.. i'll try it tomorrow since i'm working today.. i'll let you know how it turns out..
Old Jun 28, 2009 | 01:29 PM
michael l's Avatar
by the way how wide are your 27's and the 28's that your friends have.. are they 9" or 10" wide..
