Blaster throttle cable question
Old Feb 18, 2001 | 02:04 PM
exer's Avatar
On my sons 2000 Blaster, it has been "cutting out". I noticed that if you put slight tensinion on the throttle cable while sitting still it will also cut out, as soon as tension is releived, It will idle normal again. It only seems to cut out around a certain RPM and it seems to be mostly at lower speeds. It is like it dies and then starts back up again, backfiring in the process. Any help on this problem would be appreciated.
Thanks, Exer
P.S.- It is completely stock
Old Feb 18, 2001 | 02:30 PM
Blastermaster's Avatar
the cutting out you have wile giving it gas wile you are at idel is the t.o.r.s. your cabel is to tight and it is pulling cabel befor the switch is let out(same thing hapened to me) i don`t know about your top end problem
Old Feb 18, 2001 | 05:17 PM
FMFblaster1586's Avatar
Mine hits the plastic grill and whenever you turn left it revs so I just moved the wire. It was annoying.
Old Feb 19, 2001 | 10:30 AM
dirt817's Avatar
that's most likely the t.o.r.s. system. try unplugging the wire harness the leads from the top of the carb. It should run without any problems. If it doesn't work, then your problem could be jetting or ignition. Good Luck!
scram5050
Aug 30, 2024 01:39 PM
GregM
Mar 6, 2018 06:53 AM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
skeets44
Jul 17, 2015 01:04 PM
timster911
Jul 13, 2015 01:57 PM
