Cam swap on a 97 500 sportsman
Old Jun 30, 2009 | 11:18 AM
Rutcutter's Avatar
Default Cam swap on a 97 500 sportsman
I was wondering if anyone has any tips on swapping a cam on a 97 500,also whats the trick on the compression release setup?
Old Jun 30, 2009 | 01:52 PM
Rutcutter's Avatar
So nobody has any advice on this procedure? The only thing that concerns me is the compression release setup on the cam.
Old Jun 30, 2009 | 08:10 PM
The detent spring and entire detent lever can slide out if you turn cam up on its side,confusing a lot of people on how it goes back! With cam level look at spring and how it winds against lever and cam stop pin. Should be able to to push detent lever up and should spring back.In the middle of the cam you can see the ball bearing it pushes up and down.
Old Jun 30, 2009 | 08:16 PM
Rutcutter's Avatar
The cam I have came out of a running parts bike and looks like the detent lever and everything is still intact on the cam,do I need to do anything other than install it? LOL Im stumped when it comes to this point in the process..
Thank you for responding old polaris tech it means alot..
Old Jun 30, 2009 | 08:31 PM
Just pull cam cover plate on left side of engine,after you have at TDC and removed cam sprocket. just slide old one out and new one in,replace sprocket and cam cover plate and detent wont go anywhere. GOT AHEAD of myself!! After you have at TDC,remove tensioner and replace after everything else is buttoned up. Tensioner must be set all the way back and will readjust after you pull the recoil slowly.
Old Jul 1, 2009 | 08:34 AM
Rutcutter's Avatar
Valve lash .006 exh and intake ?
Old Jul 1, 2009 | 04:35 PM
Kerbbirds's Avatar
yes, .006 is right what year quad is it that you pulled the cam out of?
Old Jul 1, 2009 | 04:52 PM
Rutcutter's Avatar
Old Jul 5, 2009 | 03:25 PM
Rutcutter's Avatar
Well just wanted to update the thread,I installed another cam in my 500 Friday and it runs like a champ now.. The job wasnt bad at all,took me 3hrs start/finish. Thanks for all the help guys.
bzdok1234
30
Feb 23, 2016 01:55 PM
cdoren
Aug 16, 2015 11:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
