HELP
Old Feb 18, 2001 | 03:26 PM
seanl's Avatar
I striped my oil plug hole, not the bolt, What should i do? Will a heli-coil work or mabey tap it out? If i do one of these will i have to worry about metal fillings in the transmission? I have to get this fixed by tuesday because someone is coming to look at it and mabey buy it! WHAT TIMING!!!! I know their a tech tip on this site about this problem but my computer does not load it up. I would be forever greatful if someone could post that page in this thread or e- mail me it seanl@superior.net
Thanks a Bunch
sean
Old Feb 18, 2001 | 03:29 PM
H300F's Avatar
yeah I don't know which one works the best but I know you can re-tread them. Don't worry about the metal fillings they should fall out not in.
If your quad is a lt250r i think you can tread the hole to 12mm and put in a honda 250r drain bolt... but maybe it is the other way around retread honda, put in suzuki bolt. not to sure
someone will know though
Old Feb 18, 2001 | 03:33 PM
mster's Avatar
i sent the tech tip to your e-mail
hope it helps
Old Feb 18, 2001 | 03:34 PM
H300F's Avatar
hey just found out from ct racing which way it was
If you have stripped a 12mm oil drain bolt (TRX250R) you can simply re-tap the hole to 14mm X 1.25 and replace the bolt with a Suzuki LT250R drain bolt.
