how to install kill switch 400ex
Old Jul 7, 2009 | 06:19 PM
stock400's Avatar
Smile how to install kill switch 400ex
hi i,m from quebec i just boujht a kill switch and would like to know if someone can help me... got 2 wire one short and the other one a bit longer where do i put them thank for the help and sorry about my writhing,,
Old Jul 7, 2009 | 09:16 PM
450r racer #307's Avatar
the easiest way is to wire it into your ignition take the shorter wire and hook it up to the black wire , i believe, coming from the key switch. the longer wire just put a wire clamp on it to put it on a bolt that attaches to the frame, metal on metal.
Old Jul 9, 2009 | 03:31 PM
gsjeepxr's Avatar
im running the pro armor kill switch, and i had to hook one wire to a ground and the other ties inline with the green wire on the ignition coil. when the switch is pulled it grounds out the coil. tried doing it to the key switch first and blew a fuse, then read the instructions and realized it needed to tie in with the coil.
Old Jul 9, 2009 | 08:23 PM
stock400's Avatar
Default kill switch
thanks a lot man it working and didnt blew any fuse thank again now up to the track all i needed to go there
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Ripinandtearin
Dec 11, 2017 08:06 PM
sweaver
11
Aug 18, 2015 03:47 PM
Hatrackr
Aug 11, 2015 09:03 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
