Battery chargers
Old Jul 8, 2009 | 10:00 PM
RticKwad's Avatar
Runs Stealth!
Default Battery chargers
All,
I was wondering what you all recommend for a full battery charger (not tender) to charging our 12v batteries?
Regards,
R'
Old Jul 8, 2009 | 10:23 PM
eggenz7's Avatar
any trickle charger will work..not enough battery there to take 10 amps to charge with
Old Jul 9, 2009 | 12:39 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
If you are talking about a normal battery charger to have around the garage/house.
I have one just from a local parts store that does 2 amp 10 amp and has a 50 amp starting .....Also FULL Auto shut-off is a must ......
Mine also has the Deep-cycle switch for my boat batteries.......Caper.
Old Jul 9, 2009 | 12:53 AM
CaptainQuint's Avatar
I use two different types of chargers
A small Battery Minder model:
BatteryMinder Battery Charger / Maintainer with Desulphator — 12 Volt 2/4/8 Amp, Model# 12248 | Battery Maintainers | Northern Tool + Equipment
And a larger Schumacher wheeled charger/starter:
Schumacher Wheeled Starter/Charger — 200/100/40/10/2 Amp, Manual, Model# SE-4022 | Battery Chargers | Northern Tool + Equipment
For most purposes the Battery Minder model is more than enough and does some fancy stuff the big Schumacher model doesn't. I tend to charge stuff on the Battery Minder and use the wheeled Schumacher for larger jobs like jump starting and such.
Old Jul 20, 2009 | 07:43 AM
RticKwad's Avatar
Runs Stealth!
Thanks all for all the input! (Still figuring out the subscriptions thing with the new forum, lol)
Cheers,
R'
Old Jul 20, 2009 | 10:54 PM
bentarrow's Avatar
First Things First!
I use a Vector(Black and Decker) for everything from the small ATVs to the 2 6 volt Interstates in the RV. They are 2/10/25/amp with 75 amp jump start. Sam's Club or on the web for $50.
Old Jul 21, 2009 | 09:21 PM
RticKwad's Avatar
Runs Stealth!
Thats what I need to do is just go there anf buy the charger. I assume its like jumper cable type terminals?
R'
Old Jul 21, 2009 | 09:54 PM
war1ock's Avatar
I jsut use an automotive charger charger that has 6volt and 12 volt option. I hook it up and let it charge for about 15 minutes and it charges it great
Old Jul 22, 2009 | 12:20 AM
Killjoy's Avatar
After a lot of expensive lessons learned, I bought a YUASA 1.5A charger/tender. Best $50 investment I've made on the quad.
YUASA is a major battery manufacturer and is the OEM battery for Polaris.
Old Sep 18, 2009 | 07:19 PM
turbo777's Avatar
I have a normal automotive one, that has 2, 10 and 50 amp. Is there any problems with using that? I am having a hard time getting my battery to charge enough to get it started. I have an 07, sportsman 800. Of course it doesn't have a pull starter. Doh!!
