Yamaha Bruin / Grizzly 350 4x4 Not working - Please help
Old Jul 10, 2009 | 08:52 AM
sanders1021's Avatar
Default Yamaha Bruin / Grizzly 350 4x4 Not working - Please help
Hello,
I have a 2006 Bruin 350 4x4. Yesterday I pulled the bike out to ride and the 4x4 is not engaging (light is not coming on either). I put it on jack stands and checked the fuse and wiring and it seems to be ok but did not get too deep in it. It does absolutely nothinig when I press the 4x4 button. The bike has maybe 50 hours on it and has never seen mud or water. Anything I can check before I send it to the dealer? I just feel like it something stupid I am missing and hate to give up the cash if I can fix it myself.
Thanks again!
Old Jul 10, 2009 | 09:05 AM
TLC's Avatar
TLC
Has to be the wire from the 4wd switch to the front diff or the wire that supplies power to the 4wd switch.
Check for any kinks or breaks in the wires all along those points also make sure all conections are pushed tight together ,. Maybe the switch itself is faulty you can take a peek if the contacts are rubbing where they should.
Old Jul 10, 2009 | 12:31 PM
going to try that tonight -it has to be something simple if the light does not work.
Old Jul 11, 2009 | 01:35 PM
Traildad's Avatar
Have you checked to see if there was power where the wire attaches to the diff? If the power is getting there then we can assume the problem is in the diff. If no power then it could be the wires, switch or fuses etc.
Old Jul 13, 2009 | 10:38 AM
TLC's Avatar
TLC
Because your 4wd light also does not work ,it most likely just a electrical thing,not anything mechanical.
RticKwad
12
Jul 19, 2015 12:22 AM
TLC
Jul 1, 2015 08:29 AM
grizzlysun
Jun 24, 2015 11:47 AM
volsgo30
Jun 4, 2015 06:07 PM
atvdave
Jun 4, 2015 06:06 PM
