banshee choke problems
Old Jul 11, 2009 | 06:58 PM
exrider91's Avatar
Default banshee choke problems
I got a 01 banshe and after it been siting 4 about a year I finally choose 2 work on it again the carbs kept leak and it was running on 1 cylinder I just cleaned out the carbs now theirs no more leak but when the chokes on only the right cylinder runs when I turn the choke off that cylinder dies and the other on runs any1 got a idea of what can b causing this problem
Old Jul 12, 2009 | 10:08 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
soun ds like you have different jetting in each carb.
Old Jul 13, 2009 | 02:08 AM
exrider91's Avatar
idk it ran fine last year with the same jets after I filled with new gas I started having alot of weird problems since like leaking carbs cylinders runing when they wanted and really bad back fires it wasn't till now I had time 2 look @ it and all I fixed was the leaks and the back fires I guess now it's just the cylinders acting up still good thing is Now the don't just start working randomly now it depends on where the choke is 2maro I'm going rip the carbs apart again and if i missed anything if that doesn't fix anything I'll look @ mayb getting used stock carbs or some good aftermarket carbs
Old Jul 25, 2009 | 12:43 PM
superyfz350's Avatar
froget a part? I frogot to put the cross tube back after I cleaned my carbs and had similar problembs. Its the small tube that is about the size of the fuel line that connects the carbs in the choke region. Let me know if this fixes it.
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
