Putting some guts in my 06 Rincon
Old Jul 13, 2009 | 03:46 PM
06RinconRider's Avatar
Default Putting some guts in my 06 Rincon
Ok, I have been Tweaking with the engine ALOT so here are the original and new specs
Orig.
Model: TRX680FA
Engine Type : 675cc liquid-cooled OHV single-cylinder four-stroke
Bore and Stroke: 102.0mm x 82.6mm
Carburetion : Programmed fuel injection with IACV idle control
Ignition : Full-transistorized type with electronic advance
Starter : Electric with auxiliary recoil
Transmission : Automatic with hydraulic torque converter, three forward gears, reverse and electronic controls
Driveline : Direct front and rear driveshafts with torque-sensitive front differential
Suspension
Front: I ndependent double-wishbone; 6.9 inches travel
Rear: Independent double-wishbone; 8.0 inches travel
Brakes
Front: Dual hydraulic 180mm disc
Rear: Single hydraulic disc
Tires
Front: 25 x 8-12 radial
Rear: 25 x 10-12 radial
Length : 83.2 inches
Width : 46.8 inches
Height : 47.5 inches
Seat Height : 34.5 inches
Ground Clearance : 10.0 inches
WheelBase : 50.8 inches
Dry Weight : 600 pounds
Fuel Capacity : 4.5 gallons, including 1.1-gallon reserve
Colors
Red
Now the NEW specs
Model: TRX680FA
Suspension
Front: Fox Racing dual wishbone independent; 7.5 inches travel
Rear: Fox Racing dual wishbone; 10.0 inches travel
Brakes
Rear: Dual hydraulic 175mm disc
Tires
Front: 30 x 10-12 Maxxis Mudzillas
Rear: 30 x 10-12 Maxxis Mudzillas
Width : 46.8 inches
Height : 53.5 inches
Dry Weight : 629 pounds
Colors
Red
Acsessories? Two 67 ford f-150 mudflaps with naked girl emblems
And the famed Truck "*****"
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
Nondem
Feb 22, 2020 12:20 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Coryco
Jul 6, 2015 07:30 PM
