2002 rubicon problems
Old Jul 14, 2009 | 04:21 PM
clip4x4's Avatar
Default 2002 rubicon problems
hello everyone. i am new to the site and need help.i have a 2002 honda rubicon and my screen blinks..i have replaced the angle sensor because that was the fault code i was getting..now the screen blinks and i cant het the "N" to come back on the screen..any help is appreciated..
Old Jul 14, 2009 | 04:52 PM
polymite's Avatar
check ALL electrical connections for moisture, clean with air and apply silicon grease to all plugs, ie. connections. This is a major problem with the es. type bikes.
al
Old Jul 14, 2009 | 06:11 PM
clip4x4's Avatar
thanks, i have took the ecu out and checked all the connections and even used dielectric on the plugs...the "--" is still blinking...is there any way i can just reset the computer..thanks again for any help.
Old Jul 15, 2009 | 05:23 AM
HondaMechanic's Avatar
Did you pre-load the angle sensor when you installed it..?
Old Jul 15, 2009 | 11:30 AM
clip4x4's Avatar
i have no idea what it means to preload the angle sensor..what would be the correct procedure to do so and is the new sensor i bought still good...everything was fine until i removed the old angle sensor..i did the troubleshooting and found that it was a code 6..i did the troubleshooting because it was sputtering in reverse..forward gears worked just fine..when i took the sensor off that is when the screen started blinking and it seems to have lost power..thanks again for any help
casey
Old Jul 16, 2009 | 05:31 AM
The angle sensor will NOT work unless pre-loaded ..
Old Jul 16, 2009 | 12:20 PM
clip4x4's Avatar
thanks for the help...is this what preloading is?
Old Jul 16, 2009 | 01:20 PM
clip4x4's Avatar
upon further investigation i see that the pin or sensor joint is not in the same position as the book...could this be my problem and is there any way i can fix this myself..thanks for all the help and participation by all..
Old Jul 16, 2009 | 04:49 PM
It will be ok when the angle sensor is pre-loaded .. The ECM uses the angle sensor to monitor the position of the swash plate , when the angle sensor is installed right the shift control motor will park the swash plate in 1st. gear ..
Old Jul 16, 2009 | 09:12 PM
clip4x4's Avatar
one last question...can soneone explain what it means to preload...and is the above diagram the procedure to do so?
