new tires help!
Old Jul 15, 2009 | 11:39 AM
Sotexy2's Avatar
Default new tires help!
so i was wondering that if i got new tires, say holeshots would they fit on my back axles?? the stock ones look awful close to touching my chain thing as it is... i was wondering if i would have to get a widening kit or they will still fit
Old Jul 15, 2009 | 12:02 PM
TLC's Avatar
TLC
The middle number on the tire is the width. Holeshot 7 inch wide are 7 inches wide, the manufacturer of the tire does not matter.
Example 25x10-12
Old Jul 15, 2009 | 12:39 PM
Sotexy2's Avatar
hmm alright thanks bud
Old Jul 15, 2009 | 04:22 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Chain thing???? What quad...300EX?
Something is very very wrong if you are having clearance problems with any of the Holeshot tires mounted on rims that are stock or close to that size! I have run Holeshots on all different types of quads for the last 20 years and never had a problem.
Can you post some pics?
Old Jul 15, 2009 | 06:55 PM
Sotexy2's Avatar
i dont got them yet but they look like they would become to close to my rear skid plate or rub against it
Old Jul 16, 2009 | 08:06 AM
Red Rider
Again, what model of quad? Your picture looks like a 300EX (seeing you mentioned a "chain"), but also looks kind of like it could be a 250EX which is shaft drive.
Which Holeshot models are you talking about??? You aren't trying to run utility ATR's on your little EX are you????
I just can't imagine you actually have any issue here! Should be miles of clearance with any other Holeshot model, and your skid plate is on the bottom so it should not be an issue, unless your quad has some very weird mods (like a really skinny axle).
I ran Holeshot XC's (22' front/20" rear) on my 300EX and 250EX's. The XCT's (23" front/22" rear) give a little more ground clearance, but are kind of heavy for a smaller quad. If you are on a budget, the Standard Holeshots (21" front/20" rear) are light, but wear out a little quickly.
Old Jul 16, 2009 | 09:48 AM
Sotexy2's Avatar
its a 250 ill take a picture but the holeshots arent to much wider than the stock tires are they? i wanna get the holeshot SR just for the rear with baja rims
Old Jul 16, 2009 | 10:33 AM
TLC's Avatar
TLC
Whats the tires size? If the numbers are the same as the old stock tires how can they be wider?
They do not make 22x7-10 that are 8" wide or they would be calld 22x8-10 instead.
Old Jul 16, 2009 | 11:50 AM
Sotexy2's Avatar
rear for the holeshot sr are 20/10R9 so im assuming i need to get a 9x9 t-9 baja rim
Old Jul 16, 2009 | 12:09 PM
Sotexy2's Avatar
does anyone know anything about the SR?? are they good tires and last long?
