01 400ex rear shock fit on a 93 300ex.
Old Jul 17, 2009 | 09:48 AM
Triggerfreak's Avatar
Question 01 400ex rear shock fit on a 93 300ex.
Will a rear shock off of a 2001 honda 400ex fit on a 1993 honda 300ex.Thanks!
Old Jul 17, 2009 | 03:15 PM
gsjeepxr's Avatar
nah its completely different. you need a o1 raptor shock.do a search theres alot of info on it. 400ex fronts will bolt on with the help of a diamond customs bracket. which greatly improves the 300
Old Jul 25, 2009 | 09:24 AM
Will a rear shock off or a 06 yamaha 450 fit on it or no also.
Old Jul 25, 2009 | 09:19 PM
gsjeepxr's Avatar
doubt it. do a search on here. theres articles about it. the 01 raptor 660 or aftermarket are your choices. herd the rappy shock makes a huge difference. i know the 400 frnt conversion on my 300 did
Old Jul 26, 2009 | 12:05 PM
95wolv's Avatar
I believe the rear shock from a Warrior will also fit, and it has the long hose for the resivoir so you can mount it anywhere. The biggest problem with the 01 Raptor rear is the very short hose on the res, I had to put a 14" long one on so I could clamp the res to the frame on my son's 300ex. Warrior shocks may not be as good as Raptor shocks, but there are a lot more of them out there, and probably a lot cheaper.
Old Aug 11, 2009 | 09:35 AM
Todd T's Avatar
Any year warrior shock do?
Old Aug 11, 2009 | 01:40 PM
95wolv's Avatar
I don't think they changed them, as long as the bottom is set up the same as the 300ex shock, it should bolt in.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
07Redrider400
Jul 25, 2015 05:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
