What needs to be maintained and lubricated regularly?
Old Jul 17, 2009 | 04:24 PM
tehpwnerer19's Avatar
Default What needs to be maintained and lubricated regularly?
Just wondering what on my wife's 07 AC 400 should be lubricated and maintained regularly? I change the oil when I am supposed to and service the air filer thats about it. Her steering is hard to turn and I am wondering if there's something I should lube? Im sure everything that was factory lubricated was with the cheapest non-waterproof grease available. Thanks/
Old Jul 17, 2009 | 06:15 PM
08700efi's Avatar
im pretty sure most cats this new are all sealed and there are no zerks, read your owners manual it it will tell you everything you need to know about maintenance on your specific machine
Old Jul 17, 2009 | 10:00 PM
mudslinginfool's Avatar
Does it in the Mud!
no lube anywhere required except the engine and differentials. steering post may be bent a bit,or its too tight maybe. No reason for it to be real tight.
Old Jul 17, 2009 | 10:07 PM
How do you loosen it ? Doesnt look bent.
Old Jul 18, 2009 | 09:52 AM
Does it in the Mud!
im not sure but my guess is where the top of your plastic is. you may need to take off your plastic and look where your post goes down. Also,sometimes the paint on the post gets caught in the clamp holding the steering post and makes for a hard steering. You could also try spraying some lube down the post and see if that helps,but once you wash it ,it may do it again.
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
DMIMAGE
ATV Expeditions
Sep 20, 2015 06:56 AM
rgjackson
Sep 17, 2015 11:21 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
