2004 polaris predator 500
Hello I am looking for some advice on using the right main jet for my pred I live in the south eastern part of wisconsin and I have been told that were between 0-1,000 ft in elevation I have the pure polaris white brothers pipe on it running 8 discs stock air box and snorkel with a k&n panel filter and 5 uni vents in the back any suggestions on jet size would be great.
Thank you
Thank you
Personally I would stick to the stock carb jets and not mess around with the Dynajet. If you have the PP pipe and a drop in K&N I doubt you would have to run more the 155-160 main range. Start at the 160 to be safe and come down if you have to. The PP pipe recommends stock jetting and with you air box cover on should have to go up to much. What are you at now? My money would be on the 155 if I was a betting man but again better be safe the sorry. If you really want to wake you Pred up get a clamp on filter and start jetting around the 170 range and drop the needle clip one down from the blunt end. Good Luck!
