grizzly 660 high rev tops out at 35
Old Jul 25, 2009 | 08:28 PM
IQSLEDNECK's Avatar
Default grizzly 660 high rev tops out at 35
i was riding my wheeler today and got stuck, after that it started rev ing high and now will only do 35mph.. whats wrong??
Old Jul 25, 2009 | 09:09 PM
TLC's Avatar
TLC
Is it low range? If not did the belt get wet or is it due for a change.
Old Jul 26, 2009 | 10:31 AM
IQSLEDNECK's Avatar
the belt didnt get wet, and it only has 500 miles on it. The indicator says it is in high range... I was thinking there might be a sensor that might be shorting out, keeping the ATV from going in to high gear but it telling the indicator it is in high range. Cause that exactly what it feels like... It feels like it is in LOW RANGE but the High range light is on.
Old Jul 26, 2009 | 10:48 AM
TLC's Avatar
TLC
You could check by disconnecting the rod beween shifter and tranny lever and manually force the tranny lever into high range to see if thats the problem.
Old Jul 26, 2009 | 11:52 AM
95wolv's Avatar
Were you stuck in mud/water? it is possible your clutch got full of crud, and now it won't shift up and allow the belt to ride up the sheave and give the higher gear ratio that lets you get to top speed, like it is stuck in low gear. Pull the belt cover and see if the clutches look all dirty and mucked up, could be time for a clean up and more "Grizzly Grease"
Old Jul 26, 2009 | 04:06 PM
IQSLEDNECK's Avatar
I puller the clutch cover and it looks clean and dry... I dont know were else to go from here
Old Jul 26, 2009 | 09:16 PM
95wolv's Avatar
Then it looks like TLC and IQ are the guys to talk to , see if their recommendations of checking your shift linkage works out, if it comes a little loose, it could keep you from getting the trans into hi range, and make you rev out and keep lower speeds.
Old Jul 27, 2009 | 10:20 AM
09 popo HO's Avatar
If you put it into low is there any difference? Try going from high to low and back. Maybe it will fix itself. Thats what I always hope for when theres a problem.
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
RticKwad
Jul 21, 2015 03:00 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
