grizzly 660 high rev tops out at 35
the belt didnt get wet, and it only has 500 miles on it. The indicator says it is in high range... I was thinking there might be a sensor that might be shorting out, keeping the ATV from going in to high gear but it telling the indicator it is in high range. Cause that exactly what it feels like... It feels like it is in LOW RANGE but the High range light is on.
Were you stuck in mud/water? it is possible your clutch got full of crud, and now it won't shift up and allow the belt to ride up the sheave and give the higher gear ratio that lets you get to top speed, like it is stuck in low gear. Pull the belt cover and see if the clutches look all dirty and mucked up, could be time for a clean up and more "Grizzly Grease"
Then it looks like TLC and IQ are the guys to talk to , see if their recommendations of checking your shift linkage works out, if it comes a little loose, it could keep you from getting the trans into hi range, and make you rev out and keep lower speeds.
bpegram84
Jul 22, 2015 08:15 AM
RticKwad
Jul 21, 2015 03:00 PM
