grizzly 700 jumps outta gear
Old Jul 26, 2009 | 03:17 PM
mud hauler's Avatar
Default grizzly 700 jumps outta gear
when i have my grizz in either park or neutral and i hit the start switch, it tries to turn over then jumps into reverse (at least the indication on the dash shows it's switching into reverse). if i hold down the start switch it'll eventually start up but it's just kinda annoying and probably wearing my starter out pretty fast. anyone have any idea what could be causing this?
Old Jul 26, 2009 | 05:53 PM
HeftyLefty's Avatar
Have you adjusted the shifter linkage to the transmission?.
Pull plastic on tranny side.
Disconnect linkage.
With key on, shift tranny by hand until neutral shows on pod. Verify by rolling quad. Turn key off.
Move shift lever to neutral.
Reconnect linkage, adjust out slack, verify solid engagement for each gear.
Lubricate linkage.
Replace plastic.
If still having problems, take to dealer.
Old Jul 26, 2009 | 08:50 PM
mud hauler's Avatar
thats what i thought at first too, but it jumps up to reverse when in park, and down to reverse when in neutral. if it were the linkage, wouldn't it jump up to high when in neutral?
Old Jul 27, 2009 | 06:18 AM
HeftyLefty's Avatar
If adjusting the linkage doesn't fix it, I would suspect the shifter fork in the transmission is the culprit.
Unless you know how to fix it, (I don't), take it to the dealer or qualified repair shop.
Old Jul 27, 2009 | 01:54 PM
mud hauler's Avatar
i'm gonna mess with the connecting rod pretty soon, hope that fixes it
skinnyr6
Aug 25, 2023 02:18 AM
greg74
Sep 10, 2019 03:03 PM
black_thunder
Jul 26, 2015 09:23 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
