250r swingarm needle bearings
Old Feb 20, 2001 | 12:02 AM
evhwg's Avatar
im trying to get the needle bearings out of my 88 250r swingarm. so far no luck. do you guys have any ideas?
i cut the bolt out with a sawzaw now im stuck on this.
Old Feb 20, 2001 | 11:07 AM
Lasher's Avatar
My bearings were stuck in there pretty good as well.
I used a torch to heat up the bearing and them used a screw driver to pry the outer race away from the swingarm. Once I could get a grip on the bearing, I used a set of needle nose pliers to pull it out. Too some time but I got one out.
The other side I used a socket that just fit into the swingarm and pounded it out.
Good luck. This was one of the hardest parts of my rebuild.
Old Feb 20, 2001 | 12:55 PM
Dill's Avatar
I had to use chisels and chisel the bearing out. I've heard a dremel tool or die grinder will work for cutting the bearing race out too.
tip for you..do NOT put needle bearings back in...Helms enterprises makes a nifty teflon bushing kit that is cheap, and easy to replace when they wear out. The ad is in the back of DW and 4WA
Old Feb 20, 2001 | 07:50 PM
evhwg's Avatar
i already bought the pivot works rebuild for it.
but next time i will try those bushings. right now my friend has it and is asking around to see if his friend at a machine shop can get them out.
this so far has been the hardest part. the bolt and the needle bearings. im afraid when im done i wont want to get this thing dirty
exmotocrosser
Sep 13, 2019 06:12 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
wrencher82
Sep 24, 2015 03:39 PM
jbrewster94
Sep 23, 2015 04:16 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
