Scrambler 400 starting problems
Old Aug 15, 2009 | 03:29 AM
brixman's Avatar
Exclamation Scrambler 400 starting problems
I just bought a 95 scrambler and when I got it home, I cleaned the carb. I don't know much about carbs, but hope someone can give me a little guidance. It is a major pain in the butt to get started. I have to choke it and give all throttle at roughly half way through the motion of pull starting. If I don't get it the first time, it backfires the next try. After I do get it running is seems to run fine, not quite as powerful as I thought but have nothing to compare it to (new to quads). I am wondering if I accidentily bumped something when cleanin the carb, and how do I try to set all setting back to stock ranges. Thanks for any and all help
brixman
Old Aug 15, 2009 | 07:46 AM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Take the carb off, take apart and clean pilot jet, main jet, and lube up choke cable, really simple to do
Old Aug 15, 2009 | 10:23 PM
brixman's Avatar
Smile
I did that today, and it helped a little but it is still a beast to get started. I changed the plug, set the mixture screw out 1 &1/2 turn out from seat. I didn't seem to change anything. Thanks for the help though
Old Aug 24, 2009 | 07:05 PM
Nick Danger's Avatar
Sounds like a choke problem. Got a service manual? I am not use to this new format that that this site changed to, but there ought to be a history search on carburators, which will show you step by step how to take the carb off and bebuild it. There is a plunger in the choke... it may be defective. Keep asking and reseaching
Old Aug 24, 2009 | 08:01 PM
eggenz7's Avatar
i would be there is an air leak somewhere. i bet the seals on the crankshaft are bad. after you get the motor started spray carb cleaner on all boots to rule them out.
Old Aug 24, 2009 | 08:06 PM
eggenz7's Avatar
stupid dbl post
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
hoopduerr
Jun 1, 2015 08:22 PM
1000gade
May 27, 2015 12:37 PM
