sportsman 700 choking out
Old Aug 17, 2009 | 06:25 PM
shanekurtis's Avatar
Default sportsman 700 choking out
im working on a 04 polaris sportsman 700 and it starts and runs when the choke is pulled out and will continue to run untill it is about 1\4 of the way out then it cuts out and dies and the carb has been cleaned from top to bottom also if you pin it it will run for a few seconds with the choke in all the way im thinking its vaccum or getting starved somwhere any help is appreciated thank you
Old Aug 17, 2009 | 07:06 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
heck the carb boot to see if its cracked. a few 700's were known for it.
Old Aug 17, 2009 | 07:09 PM
I'd first recheck your pilot and main jets. If has to have choke to run,sounds like fuel starvation. Also can check the fuel line,disconnect line and crank engine over,should have decent flow. Can eliminate fuel pump if flowing ok. Also what stendori said! Bad about splitting at clamp.
Old Aug 20, 2009 | 09:45 AM
red_neck06's Avatar
I had both the 2 intake tubes go bad on my 02 700. They both split and were dryrotted like crazy. That is exactly what mine did before I replaced the to intakes, also check your plug wires for worn spots (even if the cores not showing, it arcs through the rubber) so tape them up.... another thing make sure that ur not running with out the intake neck(ontop of the lid) that makes mine stumble all over its self.
Old Aug 20, 2009 | 10:22 PM
m.jones101604's Avatar
If the machine is warm enough to build up pressure in tank could be clogged vent line could also poss. be the choke, idle and or throttle adjustment
Old Aug 23, 2009 | 07:22 PM
i have checked the fuel lines and they flow the fuel **** is perfect um spark plugs wires and caps are working with no flaws as goes the jets there is no clogs everything is good and there was no visual damage on the rubber boot and i actually ran it with out the air box lid and it ran better so should i tinker with the air/fuel mixture
Old Aug 23, 2009 | 07:58 PM
red_neck06's Avatar
not trying to be a smart *** or call you stupid. But the cracks are or can be hard to see, best thing to do is(mine was so bad that i could push on the carb and it would seal the crack and idle with the choke off) but take carb cleaner, ether, or brake cleaner and spray it on both your boots. What about the intake gasket on the head?
Old Aug 23, 2009 | 09:34 PM
Moosedog's Avatar
I just fixed that on my 600 it was the carb mount boot. Couldnt tell until I pulled the carb.
Old Aug 24, 2009 | 12:40 PM
i know that its hard to see since its rubber but i ment i checked it out with out taking it off but i took it off last night and there is a small crack on the inside of the collar so now its just waiting for a new one to come
