Setting IDLE (SP800)
Old Aug 23, 2009 | 08:16 PM
RticKwad's Avatar
Runs Stealth!
Default Setting IDLE (SP800)
All, I am averging about 1280 to 1310 RPMS on my SP800. Is that normal?
Also, if I do set the IDLE lower, would it just be less throttle repsonse? Or could low idle do any damage to the motor or carb?
Thanks for the input!
Cheers,
R'
Old Aug 23, 2009 | 08:33 PM
Sportsman800's Avatar
The service manual states taht the idle should be 1150 rpm + or - 100 rpm, so you are out of spec at that range.
Old Aug 24, 2009 | 05:05 AM
700 sportsman's Avatar
Yours is a Carb R'? Also I got a copy of your service manual if you want it let me know
Old Aug 24, 2009 | 06:02 AM
RticKwad's Avatar
Runs Stealth!
Your right EFI not Carb. Recent memories of my SP450 making idle adjustments with cleaning the CARB. Okay so something is going on here w/my SP800. Suggestions as to what is making my RPMs so HIGH?
Thx,
R'
Old Aug 24, 2009 | 07:16 AM
UTU's Avatar
UTU
Default high idle.
1st..Check the throttle body/butterfly valve LOTS of time these will gum up opening the butterfly valve a lil resulting in a higher idle. You can get throttle body cleaner at parts store use a tooth brush/brush too..... There is a procedure for adjusting the idle in the service manual (EFI)....I would check/CLEAN the throttle body FIRST...
OOOOPS! I just noticed you are running K&N.There has been a lot of riders with K&N filters with the throttle body gumming up the butterfly valve resulting in the higher idle. If you keep running the K&N be sure NOT to have excess oil on the filter when cleaning/reinstalling!!!!!!!!!!!!!
Old Aug 24, 2009 | 06:30 PM
Check the throttle cable, too make sure it's not twisted or something goofy
Old Aug 24, 2009 | 07:49 PM
scrambler400enoge's Avatar
Shapeshifter Rider
I would think it would be dual carb because it's a twin cylinder?
Old Aug 24, 2009 | 08:17 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
there is only 1 throttle body on these.
stendori's Avatar
Super Quad Patrol
I'm watching you!
Old Aug 24, 2009 | 08:50 PM
RticKwad's Avatar
Runs Stealth!
Cool thanks for the info. ! UTU I was exp this high RPM with my paper filter. I did however put my K&N back in and the high RPM is consistent. I am leaning more to the throttle body or something else. All good info. thanks a bunch gentleman!
R'
Firefighter400
Oct 8, 2022 06:38 PM
slowgsxr97
Mar 18, 2022 03:40 AM
donintennessee
Aug 19, 2015 02:22 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
ghost civic
Jul 30, 2015 04:09 PM
