Removing intake manifold
Old Aug 24, 2009 | 01:11 PM
talonxracer's Avatar
Default Removing intake manifold
Is there any trick to reaching the upper allen bolt/screw on the intake mani on the DS650 with the engine stil in the frame? It looks very well tucked in there. Will a ball end 5mm allen reach in there and get enough purchase to remove the screw?
Thnx Doug
Old Aug 24, 2009 | 02:53 PM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
Remove the two outer bolts first.
With ballend allen in place, tap lower right side of intake with rubber mallet or brass or wood.
You want to slightly raise manifold counterclockwise and turn bolt at same time.
OMR
Old Aug 24, 2009 | 03:12 PM
Thnx for the tip!
bmxatv10
Oct 14, 2022 06:23 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Hw00d
Sep 10, 2015 08:53 AM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
