Snow Plow for 500efi Any Suggestions???
Old Aug 25, 2009 | 01:09 PM
Lugnut03's Avatar
Default Snow Plow for 500efi Any Suggestions???
I have a 2006 500 EFI Sportsman.....What size plow should I get? is 60" too big?
Old Aug 25, 2009 | 02:48 PM
behindredeyes's Avatar
60" is definately not too big. My 400 pushes it just fine with only stock tires. I heard with a 48" blade the snow falls back under the tires if you're pushing a fair amount. Also if you angle the blade you will want the extra width.
Old Aug 25, 2009 | 03:36 PM
Lugnut03's Avatar
Thanks for the info, can you suggest a brand?
Old Aug 25, 2009 | 03:44 PM
I have the Glacier 2 plow and I have had no problems with it. I know others on here think it maybe a bit weaker than other set ups, I guess it all depends how much snow you will be moving. I like it as it can be taken on or off in a couple of seconds, I'm sure there are other brands that do the same.
Old Aug 25, 2009 | 11:59 PM
switzomatic's Avatar
Default plow
I'm a fan of the Glacier. I have a Glacier I that spent four years on my 05 800 and is now mounted on my 09 800 and upgraded to the RZR blade. Your 500 should push no problem. If you do a lot of plowing with it I'd suggest installing a clutch kit if you haven't already to add some low-end grunt.
Old Aug 26, 2009 | 10:25 AM
Lugnut03's Avatar
Thank you for the feedback! I was looking at the glaciers as well. I will keep the clutch kit in mind. WHat brand of clutch kit did you go with?
Old Aug 26, 2009 | 12:11 PM
Another good investment would be to upgrade the front springs, The plow is quite heavy and the front end sags quite a bit. Mine sags with out the plow on it for that matter.
Old Aug 26, 2009 | 01:29 PM
Default ?
I believe I had an EFI Outlaw clutch kit on my 05. Haven't gotten around to my 09 yet. Waiting for the warranty to run out at the end of September.
Old Aug 26, 2009 | 02:58 PM
700 sportsman's Avatar
I have a Warn Plow Setup, and yes it has push tubes, and is sometimes a pain to take on and off, but I don't usually take it off in the winter much any way, and IMO the push tubes distribute the force from the blade to the frame better, also on the topic of HD springs, mine did sag quite a bit, but most people I talked to that installed the HD Springs weren't too fond of the rougher ride with out the plow, so I and several others used spring spacers, that are 2" tall, and are made from 2" diameter Pipe, some used plastic, and I used metal, but I don't think that it really matters much, but my sagging is gone, and the ride is the same, my front end just sits level when I don't have the plow on, and if you want any pics or more info on anything, let me know
Old Aug 26, 2009 | 03:47 PM
Default Plow
If you're interested in a glacier I still have the 60" straight blade. You would have to get the mount which is about $100 and it could use a new wear blade on the bottom(@ $25) but you would still save a lot from buying a complete system. I'd probably sell it for $50 plus shipping.
