kazuma 110 idle problems!
Old Sep 2, 2009 | 01:12 PM
gparker's Avatar
Default kazuma 110 idle problems!
my sons 110 kazuma will not idle right. after its cranked up it sometimes idles good for a minute then it will shoot up real high, then drop way down, it does this until it finally dies. i have tried adjusting the fuel and idle screws, but cant get it right. do you think this is a carb problem or something else????????
Old Sep 2, 2009 | 05:41 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum gparker!
If it ran good for a while and now does this Id say the carbs dirty....does this machine have a fuel filter? If your still using the stock spark plug I would buy a NGK C7HSA and replace the stock plug..
Old Sep 2, 2009 | 08:00 PM
gparker's Avatar
it doesnt have a fuel filter, but it has a new carb and a new plug. I just dont know, and if someone could tell me the valve clearance specs that would be great
Old Sep 2, 2009 | 09:26 PM
KTM Patrol
Former Chinese POW!
Id get a fuel filter..it will keep the carb clean and working well....Set the valves with .003-.004 of clearance...
Old Sep 2, 2009 | 10:52 PM
gparker's Avatar
thankyou, now ive got the idle fixed, it smokes real bad when in wot, it seems fine in idle or going slow, any suggestions? I just put a new head assembly, piston and rings on, you think i put the rings in wrong???
Old Sep 3, 2009 | 07:29 AM
KTM Patrol
Former Chinese POW!
Did you check the ring gap before putting it together?
Old Sep 4, 2009 | 04:12 PM
gparker's Avatar
do you know the correct gap in the rings??
Old Sep 4, 2009 | 04:50 PM
KTM Patrol
Former Chinese POW!
Off the top of my head Id say about .007
I base that on a old school theory of .0035 for every inch of bore...2" bore = .007 ring gap..
Im guessing at your bore size..
Old Sep 4, 2009 | 04:54 PM
KTM Patrol
Former Chinese POW!
Another thing to do is stagger the ring openings 180º from each other...top ring opening on one side...next ring opening 180º from that... bottom set 180º from that.
Old Sep 5, 2009 | 09:10 PM
windtrader's Avatar
Are these usually available at regular auto stores like kragen, pep boys, or cycle gear, or ??? thx
