Mojave voltage regulator
Old Sep 5, 2009 | 02:47 PM
honkaw's Avatar
Default Mojave voltage regulator
Hi everyone; I have a question about my 89 Kawasaki Mojave, what does the voltage regulator do, I thought that had to do with a battery.
Old Sep 12, 2009 | 02:15 PM
07bloomfieldb's Avatar
At high rpm's the alternators (thing that generates electricity) output can reach 70-80 volts. At this voltage the alternator would melt (brushes) and you would fry the battery.
The batterys voltage should be 12.6v with no surface charge. The regulator will limit to 14.4v, as this stops the battery from gassing / shedding too much. If possible you're better off charging the battery up to 15.3v every so often. You will have to top it up fairly regularly.
If it's agm / gel don't over volt it (stick to 14.4), as you ruin it.
Old Sep 18, 2009 | 06:49 PM
honkaw's Avatar
This bike doesn't have a battery , did the later modles have battries?
Old Sep 18, 2009 | 09:32 PM
dirtjunkie's Avatar
regulates the voltage going to your lights
Old Sep 21, 2009 | 01:37 AM
Sorry I'm used to utility quads, which are all electric start etc.
Old Sep 27, 2009 | 07:37 PM
1mojave03's Avatar
No Mojaves have batteries. I have an 03. Less stuff to break down
Old Sep 28, 2009 | 01:53 AM
You try pull starting a 220 bayou in sub zero temperatures with no compression release. Now tell me you don't want electric start!
Old Sep 28, 2009 | 05:38 AM
1mojave03's Avatar
I don't PULL start... I kick....much easier..lol
Old Sep 28, 2009 | 05:20 PM
honkaw's Avatar
So , guys what does the voltage regulator do on a bike with no battery,
Old Sep 28, 2009 | 06:57 PM
1mojave03's Avatar
Regulates power to your lights.
