Mojave voltage regulator
Old Jan 1, 2010 | 10:58 AM
yamaha mechanic's Avatar
Default voltage regulator
a voltage regulator/rectifier on a bike without a battery regulates the amount of voltage put out by the stator so it doesn't fry other components, if the bike has a battery it converts ac power to dc power and recharges the battery, also regulating the amount of volts returning to the battery for charginng
Old Jan 1, 2010 | 04:35 PM
KQ400Pilot's Avatar
Originally Posted by 07bloomfieldb
At high rpm's the alternators (thing that generates electricity) output can reach 70-80 volts. At this voltage the alternator would melt (brushes) and you would fry the battery.
No, the brushes (or alternator/generator for that matter) will not melt from the voltage produced by the alternator/generator itself.
The brushes simply receive/transfer whatever voltage is produced by the alternator/generator to the wiring and voltage regulator. This is regardless of the voltage produced--whether it be 1vt or 80vt.
The voltage regulator is downstream from the alternator/generator, and shunts excess voltage (amounts over about 14.5-15.5 volts) to ground so that your battery, ignition system, lights, etc, to do not get fried.
If the brushes or alternator/generator are melting, you have much bigger issues, such as fire or a short circuit.
Joe454
Nov 20, 2020 01:19 PM
Gwolf228
Feb 18, 2017 01:36 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
