2000 500 manual shift
Old Sep 7, 2009 | 09:22 PM
hydac's Avatar
Default 2000 500 manual shift
Does anyone have the testing procedure for the stator, I have no spark and the coil tests out ok, The main ground to the motor case bolt was no good and the small ground wire in the wiring harness shorted out from the load. I replaced the wire and now there is no spark, Also is there an easy way to check the CDI if the stator checks out ok.
Thanks!
Old Sep 19, 2009 | 06:12 PM
blizzardblind's Avatar
Default cdi testing
I have a manual for the 2001 manual 500, and if it's the same cdi(which i believe it is, same part #), you can test the leads out of the cdi for the proper resistance values with an ohm meter. There's about 50 different variations of the leads to test, takes about 20 mins.
I can send the 2 pages which describe exactly how to do this along with the correct resistance readings via e-mail if you still need to test it.
Njrider1230
Jul 29, 2023 05:16 AM
merryman
Jan 19, 2016 04:29 AM
bigred20653
Aug 31, 2015 12:41 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
