Honda TRX 250R Cooling System Problem
Old Sep 10, 2009 | 05:19 PM
Lonewulf71's Avatar
Post Honda TRX 250R Cooling System Problem
Hello,
I would appreciate it if anyone can help me figure out what's going on with my 250R.
Here's the problem: It's spewing coolant out of the overflow tube as if it's overheating.
Here's the history: I completely replaced the water pump several weeks ago. I had the Honda shop install the seals. I've raced it a couple of times since and had no problems. Last race one of my hoses popped off and melted a against the head. So I replaced the top and bottom hose and put on new hose clamps. I rode it around my drive way and it seemed fine. I went to a track to practice yesterday and it kept spewing coolant out the tube. A lot of coolant. The Honda mechanic told me to check the radiator cap and to see if the coolant is circulating. I started the bike and it looked like to me that the coolant was circulating. It was moving and there were air bubbles.
Today when I took the cap off, it made a sound like it had been sealed. I put a different radiator cap on it (which who knows they could both be bad) and rode it around the driveway. It started spewing out coolant within a minute. It doesn't seem like it would even have time to actually overheat. I have another radiator but it's from a different year and takes different hoses that I don't have. I wanted to race this weekend but time's running out...
Any help would be greatly appreciated.
Thanks, Aletha
Old Sep 10, 2009 | 06:47 PM
Doctorturbo's Avatar
GOT BOOST!
Sounds like a head gasket problem to me. What happens is the piston squeezes pressure into the cooling system due to a crack or bad gasket. If the coolant does not seem hot this is more than likely the problem.
A combustion dye check would tell the real story.
Old Sep 10, 2009 | 07:42 PM
sdm111's Avatar
2 strokes or 4
Have to agree with Dr. Turbo on this one. Air bubbles in the coolant usually is a sign of a Headgasket problem.
Sep 20, 2015 02:39 PM
Land_shark1
Jul 10, 2015 12:53 AM
Jake55
Jun 29, 2015 06:43 AM
VascoConroy
Jun 12, 2015 10:30 AM
lovinhonda
Jan 25, 2000 09:17 PM
